Hi, I hope someone can help me with a problem.
Is it possible to control the media selection within a single print section using a post pagination script?
I have a 10 page document printed duplex, that uses 5 different medias:
Sheet 1 uses media 1
Sheet 2 uses media 2
Sheet 3 uses media 3
Sheet 4 uses media 4
Sheet 5 uses media 5
This has not been an issue with similar jobs I have which only use 1 or 2 media types as the standard sheet configuration can handle 3 medias, but on this job I need 5 medias to be selectable.
I can achieve the required media selections if I create 5 print sections, but unfortunately the finishing on the printer (stapling top left) does not work.
I imagine that I should be able to do this using a post pagination script but after day of reading and testing I cannot get anything to work.
Any guidance would be a great help. thank you.
