PNG image not displaying when processed
Some of my PNG images are not displaying when I process, but they do display in Preview mode in the designer.
Any ideas?
You mentioned that some of the PNGs aren’t printing. With the ones that aren’t, look for some sort of commonality between them. Were they created by the same application, do they have the same bit depth, etc?
Also, if you haven’t already, try doing a Proof Print and see if that works. It works slightly differently to the Print option at the back-end. If Proof Print works and Print doesn’t, then I’d look at the Server logs to see if there’s any error reported behind the scenes.
Best Regards
Justin Leigh
No errors in the server log, but had to make some setting changes to the dpi for some of the images to display.
