I am experiencing an issue when trying to generate PDF files from PP Connect Designer. If I insert a positional box, select it, click Preview, then print the PDF, the positional box appears on the generated file rather than being hidden as intended. The only work-around is to click of positional box then click on Design then print then the box does not appear on the PDF file. See image below for illustration.
I will hereby like to inform you that this issue is a known issue which will be fixed in the upcoming release of OL Connect and that the workaround for the moment is to make sure that you are viewing a Print Section in Design mode before executing a print via the Designer application. (93533)
