PlanetPress Connect on AWS M5
My customer is moving from AWS M4 to AWS M5. Does PlanetPress Connect work in this environment?
Has anyone tested it?
Thanks,
GB1
We tested it internally and it works. However, it hasn’t been officially certified by our QA team.
Any issue that may arise would be linked to the license (where the software may believe that it was moved to a different server).
To validate things will work as expected, you might want to install the application, activate it, and then shut down the server and turn it back on again. That will tell you if a reboot impacts the application.
Hi Phil,
Thanks for your reply. We’re going to run some tests.
