Our organization is moving certain file servers that I currently write to from Process to the cloud. Is there an Output or an Action that will allow me to send these documents to SharePoint?
Hello @sellersdp1,
The Connectors task Output to SharePoint can be used for sending files to an existing Microsoft SharePoint server in PlanetPress Suite V7.
Thank You. Here is what i am getting when I try that connector. The URL and Creds are correct. I can log in on a browser from the PP server. Is this an MFA issue?
By doing a quick search on the internet, I see that the error “The underlying connection was closed: An unexpected error occurred on a send” is usually caused by TLS.
Can you let us know please which version of SharePoint you are using?
Transcribed the error to make searching for it easier.
Error
Error getting the Document Libraries: Exception in GetWSDL: The following error was raised while setting the WSDL property "WSDL address": Exception while fetching wsdl: The underlying connection was closed: An unexpected error occurred on a send
[OK]
This is Microsoft 365 SharePoint. So I am not sure what “version” you are wanting since what I log onto in the Cloud is what I get.
A little more info. That error is displayed if I click on the Document Library toggle during setup. I get a similar error if finish the setup and try to send to that Process. here is that error from the log:
ERROR: W3001 : Error while executing plugin: Exception in GetWSDL: The following error was raised while setting the WSDL property “WSDL address”: Exception while fetching wsdl: The underlying connection was closed: An unexpected error occurred on a send
ERROR: Output to SharePoint: W1603 : Plugin failed - 10:32:52 (elapsed time: 00:00:02:698)
