PDF Splitter Problems
I’m running into issues with the pdf splitter.
For context I have a system running PP7 watch and another running OL Server.
On the OL Server when I run the pdf splitter it frequently comes up with errors saving the pdf files but when I run the same exact file on PP7 system I have no issues.
The OL Server is and I9-14900 with 64gb of ram so this is not the issue.
Any sugguestions?
Here are some of the errors I receive.
17:14:41.072 [0010] W3001 : Error while executing plugin: Error resolving data selection: : Wrong number of arguments for a setcolor operator
17:14:41.072 [0010] Set Job Infos and Variables: W1603 : Plugin failed - 17:14:41 (elapsed time: 00:00:00.053)
17:14:41.080 [0007] W3001 : Error while executing plugin: : Wrong number of arguments for a setcolor operator
17:14:41.080 [0007] PDF Splitter: W1603 : Plugin failed - 17:14:41 (elapsed time: 00:04:32.163)
To help you properly we would need to see the form and reproduce the issue. I suggest you open a technical support ticket through our website.
Also can you reproduce the same error at will when it has occurred?
If so did you try to use the exact same data file that errors out on your Connect server in your PPPSuite one?
There is no form I’m just trying to split a pdf file a client has sent me.
I did run the exact same pdf on both systems.
The errors appear at random with no consistency.
Still best to open a ticket with our support team. They can check multiple logs files and verify if it isn’t a memory issue with Workflow. It being a 32 bits application, it caps at around 1.8gb in memory.
