Hi All,
My Print Section already set the Background as ‘From PDF DataMapper input’, but I still need to include letterhead file dynamically according to data.
Kindly advise how should I do this.
Thanks and Regards,
Janice
Hi All,
Thanks and Regards,
Janice
Hi Janice,
You could achieve this by dynamically setting the stationery image for your media entry using a Control script. First create a Control script via the toolbar of the Scripts panel. Open the script and remove the sample code. The sample below sets the stationery image for the front of Media 1 based on a field called ‘someField’.
let someField = record.fields.someField
let mediaEntry = merge.template.media["Media 1"]
switch(someField) {
case 'A':
mediaEntry.stationery.front.url = 'images/stationery-A.pdf'
break;
case 'B':
mediaEntry.stationery.front.url = 'images/stationery-B.pdf'
break;
default:
mediaEntry.stationery.front.url = 'images/stationery-Other.pdf'
Hope this helps,
The sample code sets the stationery image to the Media (not the section). This allows you to have both a section background and a stationery image. Happy to have a look at your template. Not sure if that can be shared here, will send you a direct messages with my details.
