PDF based template
I do have already generated pdf, I just need to hide the existing address and add the corrected address on pdf, how can I achieve without regenerating whole pdf again. I do have multiple records in same pdf, each page has dynamic data so need to handle it page wise.
Hello @djinkal, what about applying the PDF as background image to a print section of a template and using the Clipping region option, introduced in version 2023.2 of OL Connect, for hiding the existing address?
Tip: See Section background image clipping for detailed information on this topic.
If I use pdf as background , it will be only for one, how can I handle the multiple documents-all having dynamic data of same pdf file ?
