PDF/A-3 Attachments plugin
Hi there,
Would like to know if there is a node to trigger the PDF/A-3 Attachments features from the Workflow using NodeRed? Or is there any other way which can trigger that feature without passing through workflow?
Thanks.
PDF/A-3 Currently requires Image to process, which has no NodeRed counterpart. An HTTP endpoint would need to be created in a Workflow that accepts a file, processes, and returns it back so that NodeRed can interface Image with Workflow as a proxy.
