PCL with PJL Output Preset?
Is it possible to add PJL commands to a PCL Output Preset.
In this situation there will be a separate Output Preset for each printer model.
I would need to be able to add a variable to some of the PJL commands
Such as
@PJL SET TRAY = var
@PJL SET COPIES = var
@PJL SET USERID = var
Hi UomoDelGhiaccio
it would depend on whether your printer preset supports as to whether you can access trays and Bins like that. Adding PJL instructions on the fly that is actually easier to add to a Postscript file via the JCL elements as long as the Printers PPD supports it. I’d advise contacting your local support tram with more details about what you want to do and teh hardware you want to do it with.
Alex Banahene
