PC1.2: How to suppress the "auto-snap" mechanism?
I need to position an “Positioned Box” near the upper right corner and try to drag the box to the position, but whenever I come to close to the border, the box automatically snaps the nearest border.
Other software allows to hold SHIFT AND/OR CTRL down to disable the auto-snap mechanism.
Does PC also has such key defined?
If yes: which one ist it?
if no: I’d like to see it in a future version
Horrido,
Thomas
I think what you are looking for is the SHIFT+ARROW KEY combination. If you drag a box with your mouse and come close to a border it snaps to the border. If you use the SHIFT+ARROW KEY combination however, it will just move .0105 inches to the direction you want.
If you want perfect accuracy, you have to adjust the position in the Attributes panel.
Personally, I use mouse dragging to get it go a general area, then refine with the SHIFT+ARROW and use the Attributes to get a nice rounded number which is closest to the position I want, for instance change the Y-position from 1.2317 to 1.2300.
EDIT: You have to click on the border of the box first, not inside the box.
I hope this helps,
Jelte
Hi Jelte,
yes - thanks that helps for the moment.
Horrido,
Thomas
Note that you can disable the Snap to Guides in the View menu. Shortcuts are added in v1.3 [internal ref: SHARED-35349]
