Hi
I have a field that’s “22-12-23” that I want to format to “22 December 2022”. Could someone point me in the direction on what code I need to use
James
Hi
James
When you mapped the data to a date field in the Data Mapper you could use the following script in the Designer to add the respective date in the suggested format:
let bdStr = formatter.date( record.fields.birthday, "d MMMM Y")
results.html( bdStr )
date.OL-template (7.2 KB) date.OL-datamapper (3.2 KB)
Mapping the string to a date using a custom pattern in Data Mapper.
Use the formatter object with a custom pattern in the Designer.
In case it would be “2022-12-23” instead of “22-12-23” you could use the following JavaScript code, for example:
/** See {@link https://stackoverflow.com/a/1643468} */
var monthNames = [
"January", "February", "March", "April", "May", "June", "July",
"August", "September", "October", "November", "December"
var str = "2022-12-22"; //data.extract("Date", 0);
var d = new Date(str);
var result = "";
result += d.getDate() + " ";
result += monthNames[d.getMonth()] + " ";
result += d.getFullYear();
result;
Executing the following JavaScript code will unfortunately result in Invalid Date:
var d = new Date("22-12-22");
I need it to be in the metadata like that too as I need to write out an XML also for each record. However I can add that as a action after the extract I guess within the mapper then it will be correct in the metadata
In that case you could add a second field in Data Mapper and apply Marten’s suggestion. The following example reuses the extracted date for a second field:
var monthNames = [
var d = new Date( record.birthday )
d.getDate() + " " + monthNames[d.getMonth()] + " " + d.getFullYear();
