Params in Mappers
Is the issue where if you add a property to a mapper you have to save and close the template and open it back up again for it to be available in the mapper ever going to be fixed? I thought I saw something months ago saying it was going to be fixed
Hello @jbeal84, I am able to select a new parameter when I first view the properties of another step* between step 4 and 5.
Steps to reproduce:
  1. Launch the Designer.
  2. Create a new datamapper configuration via Designer → File → New….
  3. Add an Extract step.
  4. Add a parameter in the Parameters pane.
  5. View the properties* of the Extract step.
  6. Change the Based on to Runtime parameter.
  7. Open the Parameter drop-down.
*This can be the Preprocessor step, for example.
