Papersize presets?
Is there a way 1 can cusomize a preset. I often need a c5 enveloppe and have to search for the correct measurments. Sometimes with and sometimes without a window.
It would be nice if i can make a preset for it. like the standard letter or A4.
I have used the windows search in the connect file map en checked the forum. but i cant find out where to save the templates.
Hello Jimmy,
Thanks for reaching out. We plan to introduce an feature to manage document presets [internal reference SHARED-42653]. Unfortunately it is not possible to add your own templates/presets to Connect Designer at this sage. So for now you would need to save your template in a folder on your disk and create a copy when needed (or set it to Read Only to prevent you from overwriting unintentionally).
Hi Erik!
Thanks for the quick answer!
Kind regards, Jimmy
