PANTONE Spot Color name error
I use the EDIT | Colors menu to add a spot color. For example, “PANTONE 266 U”.
In the PostScript and/or PDF output, the color name changes to “PANTONEc20266c20U”, so the RIP fails to recognize the spot color.
EDIT: When I use the “Generic PDF” output, the spot colors are named (and thus, print), correctly. It’s when I use the PostScript Level 3 output that Connect replaces spaces with “c20” in the color name, thus printing fails to use the proper spot color.
Firstly, what version of Connect are you using? I did a quick test in the latest version (2018.2.1) and found it produced the following:
4 0 obj[/Separation/PANTONE#20266#20U/DeviceCMYK 60 0 R]endobj
This worked on our FX printer in the office, but that doesn’t mean it works for all printers
By the sounds of your description this may turn out to be bug, so I recommend raising a support ticket with your local Technical Support and having it investigated further.
Best Regards
Justin Leigh
Technical Support (Asia Pacific)
Connect 2018.2.1.54383
Using Generic PDF output preset, the color names are correct. Using Generic PS LEVEL3, the spaces are replaced with “c20” and the jobs fail to produce spot colors.
Thomas
Sorry for reviving an old thread, I just want to clarify that this was indeed a bug. The issue was fixed in 2019.1.
