I want to split mit output on jobsegment level, based on a metadata field (no problem).
But now I want to add additional text to my banner page with a value from metadata on document level.
In that case I always get an error.
ApplicationException: expression 'document.metadata.MyDataField' at line 1, column 3 in pattern '${document.metadata.MyDataField}' yields undefined
Of course that metadata field exists on document level. I have created it and have selected it via the plus button in additional text.
I understand that it is not easy to handle this, because of multiple documents within one jobsegment, but wonder if there is a possibility.
Maybe that metadata document object (e.g. document.metadata.MyDataField) has an index, so I could use the document metadata?
I have tried the following but also get an error:
var docNr = document.sequence.segment - 1;
document.metadata[docNr].MyDataField;
My goal is to create a banner page per jobsegment. On that banner page I want to add the content of a data field from the first and the last record/document in the jobsegment.
Is there any way to do that in Connect output?
Thanks,
Thomas
