V.2022.2
I am receiving the W3301 error below when trying to add ‘Filename’ Metadata in Job Output Masking in my Output Preset.
I am using .csv file input and outputting to PDF. I am splitting to 1 document.
I have Filename as Document level Metadata value in my Job Presets. I can’t figure out why I am getting the W3301 error. I don’t have problems when using the standard Job Output Masking values.
Job Output Mask = ${document.metadata.Filename}-${job.nr}
[0014] W3001 : Error while executing plugin: HTTP/1.1 500 An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the output creation process caused by ApplicationException: error evaluating expression ‘document.metadata.Filename’ at line 1, column 3 in pattern ‘${document.metadata.Filename}-${job.nr}’ (SRV000042) (SRV000001)
