I have data that contains a letter and I have captured the letter contents line by line as a detail table. All I want to do is recreate the lettewr in the template but I only want to have one empty line if the data has multiple empty lines. In my css I have:
and I have a script with my selector as #grid. This is the code I’m using but it doesn’t do anything and I don’t know why.
var grid = query("#grid");
var detail = record.tables["detail"];
var last = 'first';
for (var i = 0; i < detail.length; i++) {
var line = record.tables["detail"][i].fields["line"];
if (line == "" || line == null) {
line = " ";
if (last == "" || last == null || last == " ") {
logger.info('no div');
} else {
var div = '<div>';
div += line;
div += '</div>';
grid.add(div);
last = line;
I don’t know why this doesn’t work./ I’ve also tried results.add(div) but that doedn’t wortk euither.
can someone tell me what I’m doing wrong?
I’ve also tried appending all the divs to a single srring and doing a single .add after the loop aand that doesn’tr work either
I would add a variable to check if the previous line was empty. Something like this:
let html = '';
let detail = record.tables["details"];
let prev = true;
let str = detail[i].fields.line;
if ( ! str && prev === true) {
html += '<p> </p>';
prev = false;
} else if ( str ) {
html += '<p>' + str + '</p>';
prev = true;
results.append( html );
let last = true;
let div = '';
let line = detail[i].fields.line;
line = " ";
last = false;
if (last === true) {
div += '<div>';
div += line;
div += '</div>';
last = true;
results.add(div);
but when I preview nothing is added to the div #grid and I can’t figure out what I’m doing wrong
ok I used append and that worked. what doesn’t work is its still creating empty divs multple times in a row. I’m using this:
let last = true;
let div = '';
if (! line && prev === true) {
line = " ";
last = false;
div += '<div>';
div += line;
div += '</div>';
last = true;
results.append(div);
I got it. I forgot to trim in the ddatamapper./ this was my final code:
let last = true;
let div = '';
if (line == '' && last === true) {
div += "<div> </div>";
last = false;
} else {
div += '<div>';
div += line;
div += '</div>';
last = true;
