Hi everyone,
In my workflow process I have an all in one which outputs a PDF. After that, later in the process, I have a check which if it’s true will go on a branch that needs to create another PDF. The final output needs to be a single PDF with the results of both All in one tasks. Is there a way to do this?
The second PDF is created only in certain cases, and I thought of including it already in all the templates that might get it at a certain point so I don’t need to create separate PDFs in the workflow, but this would take a lot of time (as there are around 35 templates which might get it) and also take up memory unnecessarily.
I would appreciate any suggestion!
Kind regards,
Cristian
