OL Image - I1007 Bad variable type
we are currently moving from the old PlanetPress 7.6.2.9999 to OL Connect 2023.2.0.6120.
On the new system I´m not able to create PDF/A-1b with OL Connect Image.
The error I get just says “Bad variable type” and I have no clue anymore were to look to solve it.
I created a test process that only creates the PDF (no additional plugins) and a document that only writes one fixed text in order to eliminate all other sources that could cause the error.
When I switch it to a “normal” PDF in the Image plugin, everything is working.
Does someone here know this error and can tell me how to fix this?
Could you share your test process? This would greatly help us investigating the issue.
Like I said, we are just switching to OL Connect, so we are still using .ptk Design Documents.
Here the test document.
The Process is just this:
and here the settings of the Plugin:
Recreated it here and it works fine:
I suggest you contact our Support team so they can investigate further.
(Internal reference: SHARED-92675)
Concluding note: This could be resolved by running the Workflow installer’s repair function.
At the end it turned out that the issue was caused by installing PlanetPress Suite 7 after Connect had been installed.
If really both needs to be installed on the same machine, it’s highly recommended to first install PlanetPress Suite 7, and afterwards install Connect; otherwise various issues may occur like the one discussed here.
