Hi Internal an R&D team
I am your reseller and I implement OL Ent. to customer. I know from you about performance depend on HW spec cpu, ram, HDD. So, I design server to have 2 socket cpu because I need more engines to processing job.
But server with 2 socket cpu processing very slow when compare with 1 socket cpu. I know OL have issue “Connect to run many Merge Engines (8+) simultaneously, the performance can be less than expected.”. So, i test setting from 6 - 14 merge engine but not help.
I had open case with support team but can’t fix this issue.
Yesterday I decision to clean install both of OS and OL ent with 2024.2.3 but can’t fix this issue.
You can see detail in image i compare with same data and workflow and you will see the Server1’s spec higher than Server2.
I don’t know why Server1 just use a few percentage of cpu and this is a root cause of issue.
I hope someone can help me.
