OL Create Output Task Errors
Used the Job Creation wizard in Connect Designer
  • Runtime Parameters
  • Filtering and sorting
  • Include meta data
Sent preset to Workflow
Added Create Job task to workflow
When I select the Job Preset File
Crash Dump - Current Configuration* - PReS Workflow Configuration - Exception occurred on 2022/06/10 13:29:00
PReS Workflow Version 2020.2.0.2360
Error message: Exception EAccessViolation in module ActionCreateJob.dll at 000D46C5.
Access violation at address 096A56C5 in module ‘ActionCreateJob.dll’. Read of address 00000000.
ExceptAddr: 096A56C5
hInstance: 00400000
VirtAddress: 092A46C5
Unit:
Proc:
Line: 0
Call Stack:
[096A56C5]{ActionCreateJob.dll} DllUnregisterServer + $D1679
[40005C67]{rtl60.bpl } System.@HandleAnyException + $33
Press OK
Configure Runtime Parameter and close properties.
If I re-open the task properties
But the Task runs as expected and does not error!
Hi @Joanne,
Can you let uw know please if the reported incident does still occur after executing the following steps?
  1. Hold down the CTRL + SHIFT keys and click on the PReS Workflow Configuration icon to launch the application.
  2. Keep holding down the CTRL + SHIFT keys until the PReS Workflow Configuration application has been opened.
(Sorry for the delay, I was away on holiday)
I get the same errors after launching the PReS Workflow Configuration with ctrl+shift
Looks like your workflow configuration file is corrupted. Do you have a backup of a previous version that doesn’t have that problem?
I have narrowed it down to the use of a Run Time parameter
If the Job Creation preset has a run time parameter, the workflow configuration program will error, even if the run time parameter option is subsequently de-selected.
I have attached two presets, the only difference is the presence of an unused run time parameter. The DEV_TEST preset causes the error, the DEV_TEST_NoParam does not.
DEV_TEST.OL-jobpreset (4.0 KB) DEV_TEST_NoParam.OL-jobpreset (4.0 KB)
