Ol Connect server engine configuration
i am using a server that is configured with the following resources:
CPU: AMD EPYC 9354 32-Core Processor 3.25 GHz
RAM: 192GB
OS: Windows Server 2022 Standard 21H2
Currently the OL Server is configured to use:
6 DataMapper engines with max 6096 MB of memory
22 Merge engines with max 4096 MB of memory
10 Weaver engines with max 6144 MB of memory
Given the specs above, is it an optimal configuration for the ol connect engines or can it be optimized?
Hi @Andre1
Welcome to the OL forum!
Can you please share more about the types of jobs you will be running on this environment?
Hi @butth,
we mainly produce invoices and mailings.
Actually, yesterday i set the server config to use 6 WeaverEngine, each with 10000MB of RAM. I did that because i had some out of memory errors on the weaver. I was producing 30k records.
The number of records we produce in each job, varies from ~100 to sometimes in the order of millions
