When OL Connect Enterprise is operating in a cluster, do the slave servers need to have the same disk configuration as the master server?
Hi GB1
When operating in a cluster, the secondary server s will still process their work using the same temporary file store schema as the primary server. As such, it will still need to process and store files on the secondary servers C:\ drive, though it will be using the primary servers’ database. As such, we recommend you follow the specification outlined in the Connect server help when specifying server configurations
if you want to look into this further, please open a support ticket
Alex Banahene
