OL Connect Automate - SQL Server and All in One
I need an example using a SQL Server database with Node All in One.
Thank you for your attention.
flows.zip (1.1 KB)
This is an example.
Basically you first need to upload a dummy file to your Connect Server as the All In One requires a data file. As you’ll notice, I made it permanent so you don’t have to upload it every time.
Then you set-up your Datamapper using your Database connection. Since the emulation is database, it will disregard the dummy file.
