Hi there,
I’m trying to create a workflow that takes the input from a web page.
One of the form inputs I’m trying to process is a multi select where I don’t know the quantity of the select options as they are dependent on what the user will select at the time of submission.
I’ve tried setting the name value on the select as name="addressLine[] but this give me an error
16:37:11.556 [0003] W3000 : Error parsing: Error resolving data selection: The file is not an XML file or is corrupt (Reason: Tag expected)
if I set the name value as name="addressLine[0][] I get no errors but I can’t access the submitted values from the xml in the workflow.
I’m trying to access these values in a Set Job infos and Variables task with
xmlget(‘/request[1]/values[1]/addressLine[0][1]’,Value,KeepCase,NoTrim)
But it’s not setting any value into the local variable.
[0007] Value: xmlget(‘/request[1]/values[1]/addressLine[0][1]’,Value,KeepCase,NoTrim)
[0007] JobInfo/Variable %{address1} is set to “”
