Network path when using dynamic background
Hi - I am using a dynamic background to choose one of 10 pdf’s. I have everything working just fine if I want have the pdf’s in a folder on my c drive. However I want to change the location to another network/server but can’t seem to get the path right. Currently it is looking in here:
result = “C:/Users/loon/Documents/ConnectDesigner_Work/IRASelectSignature/PDFs/”
I need it to look here: result = “//magnolia/jobs/OL-Connect/OL-IRASelectSignature/PDFs”
I have tried changing the slashes in all different directions. Adding three and four slashes in the beginning. Can anyone help with the syntax?
Thank you.
Not sure why this fails, a network path that starts with two slashes does seem to work for me:
//magnolia/jobs/OL-Connect/OL-IRASelectSignature/PDFs/
Perhaps it’s not the syntax, but something else that prevents it from working. You could also try:
file://magnolia/jobs/OL-Connect/OL-IRASelectSignature/PDFs/
Note that I added a slash at the end, it was missing in your sample code.
Do remember to be careful with using forward slashes (/) because there might be plugins that do not support this. For example the “Load External File” plugin does not accept this.
