There are several methods to achieve this. Personally, I prefer adding images for this scenario via CSS. To do this, I use a script that assigns the country code as a CSS class name to each table cell of that column. Subsequently, I define CSS rules to set the background image based on these class names.
Here are the steps:
In Design view, assign a classname like “land” to the table cell via the Attributes panel (or add it via the Source view).
Next, implement a script to add the country names as CSS class name to these cells.
The script references the “.land” class with the Scope set to “Each matched element,” automatically iterating through the results and accessing each element through the “this” object. This simplifies the process of adding information to each matched element and provides direct access to the detail record.
The script adds a class to each matched element based on the “land” field of the respective detail record:
this.addClass(this.record.fields.land)
Lastly, create the CSS style rules to set the background image for each country:
