I have a xml. I want to remove this part (all CarrierParty) with workflow. How can I do that ?
<CarrierParty>
<PartyIDs>
<ID>PREP</ID>
</PartyIDs>
<Name languageID="en-US">PREPAID</Name>
</CarrierParty>
<CarrierParty>
<PartyIDs>
<ID>PREP</ID>
</PartyIDs>
</CarrierParty>
You need to use the Open XSLT task with the following code:
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output omit-xml-declaration="no"/>
<xsl:template match="node()|@*">
<xsl:copy>
<xsl:apply-templates select="node()|@*"/>
</xsl:copy>
</xsl:template>
<xsl:template match="CarrierParty"/>
</xsl:stylesheet>
EDIT: I changed the omit-xml-declaration attribute of the XSL:output element from “yes” to “no” to ensure that the resulting XML file is fully valid.
thks Phil I will try this
Phil, it does not work but I am sure I do something wrong. In the workflow, I use open xslt, then I copy your code in it. After, what do I need to do ? When I output that to c:, the CarrierParty is still there. I have never used Open xslt
Attached is a test Workflow Configuration.
It looks for an XML file in the C:\Tests\Input folder and it outputs the modified file in C:\Tests\Output .
XSLT-Sample.OL-workflow (19.4 KB)
Use the following XML data file:
<?xml version="1.0"?>
<root>
<client>
<lastname>Dupont</lastname>
</client>
<CarrierParty>
<PartyIDs>
<ID>PREP</ID>
</PartyIDs>
</CarrierParty>
<client>
<lastname>Laplace</lastname>
</client>
</root>
Phil, it works with your file but not mine. I even tried with this
xsl:templatematch=“SyncPurchaseOrder/DataArea/PurchaseOrder/PurchaseOrderHeader/CarrierParty”/
Please post a sample file. Make sure that it doesn’t contain any sensitive data.
here is my file:
test123.xml (3.2 KB)
Phil I have found the problem. If I remove the second line of my file it works. Thks a lot
Yep, the issue is due to the namespace used by the XML. This is always a pain in the back with XSLT processes.
You can use the following code in the XSLT task instead of removing the second line of the data file:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:ns="http://abc" exclude-result-prefixes="ns">
<xsl:template match="@*|node()">
<xsl:copy>
<xsl:apply-templates select="@*|node()"/>
</xsl:copy>
</xsl:template>
<xsl:template match="ns:CarrierParty" />
</xsl:stylesheet>
