N-Up feature for creating PDF
I have a CSV file, first row contains field names, then one row is one record. I would need to create table layout, 2 columns and 10 rows (20-Up). Some data from first record should be in top left cell, from the second in top right and so on.
Does Connect Designer have an option to create N-Up layout like it was in Planet Press 7?
If not, what is the best way to achieve that?
What you’re looking for is the Imposition option in the output preset dialogue:
https://help.objectiflune.com/en/planetpress-connect-user-guide/2019.2/#designer/Output/Print/Interface/Imposition.htm
Just to be sure since you said:
Some data from first record should be in top left cell, from the second in top right and so on.”
How do you want it to behave if data from the first record is more than what the left column can handle, should it go on the right column?
Basically, what I want to know is if you want real n-up or simply to have overflow data on 2 column?
If it is real n-up, then you need to refer to imposition in our documentation.
Now if it is overflow on columns then you want to read this.
