I am using planet press 8.8 in VM and my system configuration is following
32GB Ram
2.4 GHz 10 Core CPU
we have Working shop printing bank statement it take long time to make PS file we have purchased license planet press performance pack.
how can i check the performance pack in planet press
first you should inspect the workflow log and probably also the logs of the Weaver and Merge engine to find out what exactly takes most of the time.
If i can increase the number of merge engine from Start>programs>object Lune>connect Server configuration. may it works good.
but please tell me full procedure of increase merge engines because my system hardware good software is not utilize the memory and cpu core.
there is task bar permformance i sow 2 merge engines but i have performance pack planet press connect how can increase my merge engine may i found print job ps file quickly or timely. please
You may need to read through the chapter Performance Considerations in the online manual to understand how to configure your Connect installation for best speed.
