HI there everyone,
i am a beginner in the use of Printshopmail and have a problem.
how can i fill one lay-out with 6 records without using the repetition button in the preferrences box.
and can i force a new page after the 6 records have filled the layout??
hope to hear from somebody…
jchamel
2
Do you mean you need to an N-UP of six? or do you need to have 6 records in the same record for other purposes?
I mean 6 records on one page.
however, i cant use the prefference box n-up function because the shape of the layout is not identical.
so i have 6 labels on the top of the page and then 6 bigger labels on the bottom of the page…
jchamel
4
I am afraid that what you want to do requires a Datamapper or the intervention of a modification of your data.
If that is something you encounter often, you might want to check with your sales rep at upgrading to PlanetPress Connect.
