I’ve been given a new challange by my dear boss. So for most part of the day I’ve been playing around in Designer, but I can’t quite get things right.
In my test scenario I just have a master page for the first page, one for all other pages (smaller header than the former) and 1 section filled with 18 Lorem Ipsum paragraphs.
The target is a multipage column layout. With this css I’m coming close but not quite there:
body {
-moz-column-count: 2;
-moz-column-gap: 1cm;
-webkit-column-count: 2;
-webkit-column-gap: 1cm;
column-count: 2;
column-gap: 1cm;
width: 100%;
margin-top: 3mm;
/height: 24.5cm;/
Adding the height (e.g. height: 24.5cm;) doesn’t really help. It just moves the “overflow” to a third column.
Obviously the target is that this “overflow” goes to a second page. I’ve played with every combination of page-break-before and page-break-after on the p tag I could think of, but nothing helps. I’ve also tried wrapping all the p tags in a container div and applying the above css to that div. No avail.
So I must be missing something. My big question for you is, what?
By the way. In the real live template I will be loading an externally generated html file instead of the Lorem Ipsum p tags with some variant of
query(‘html’).loadhtml(‘snippets/article.rhtml’);
This external html will mainly consist of h, p and ul (+ li) tags.
As always, every idea is welcome!
