Microsoft onedrive 365 plugin shared folder
I want to acces a shared folder has anyone figured out how to get this working?
in onedrive this is called a shortcut to My files:
is there a specific path I need to fill?
Hi Koen,
You should be able to point to this folder just like any. I don’t believe that a special path is needed.
If it’s having trouble accessing it’s most likely a permissions issue. Keep in mind that the application will have it’s permissions based on the application ID provided by Azure for this specific application.
