What does the “media rotation” setting in the Sheet Configuration tab of the Section Properties actually do?
I have a job that requires commingling, checks with a corresponding remittance document. The checks output is portrait. The remits output landscape.
In Workflow, after I Retrieve Items, Create Job, and Create Output, the result is a PDF with some pages portrait and some landscape. I run a script that uses the PDF API to rotate the landscape pages. The resulting PDF is then used as a data file for a third data map and template to apply barcodes for a folder inserter.
The script to rotate pages takes extraordinarily long, running several hours.
I had hoped to modify the Remits template to output Portrait. I thought the “Media Rotation” in the Sheet Configuration would do this, but it apparently has no effect. I still get Landscape pages.
I could think of at least two ways to cope with this…
Use a PDF splitter in Workflow, rotate with your script, do the data mapping, flag the records with a property (set property task) and then retrieve them, based in this property, to get all your records again …
Check for landscape in the data mapper, add a field with the result (e.g. orientation = “L”) and than rotate the background in the template (control script), based on this field…
best regards
-i.
Maybe I do not understand it correctly and I havent tested if its a faster appoach. So its only another approach.
Lets say you have one merged pdf with mixed orientations in the workflow as input data.
Create a datamapper configuration for the pdf file. Use “On all pages” as trigger.
1.1. Create one data field (e.g. named as “bg_pdf”) and set as javascript expression “data.fieldname”. So you have the temp filename of the pdf.
Create a design template with the following control script to create one clone per pdf page and set the pdf page as background with or without rotation to the cloned section.
merge.template.contexts.PRINT.sections[“A4”].enabled = false;
var bg_pdf = record.fields.bg_pdf;
var numClones = resource(bg_pdf).pages;
var arr_i = 0;
for( var i = 0; i < numClones; i++){
var page_start = i + 1;
var page_end = i + 1;
if(resource(bg_pdf,page_start).width > resource(bg_pdf,page_start).height){
addBackground(bg_pdf, page_start, page_end, 90);
} else {
addBackground(bg_pdf, page_start, page_end, 0);
arr_i += 1;
This approach was much faster. It completed the rotation step in 1.5hrs for a 21,000 page PDF where about 2/3s of the pages were landscape and needed to be rotated. The Run Script/PDF API approach was at about 6 hours when I finally killed the process.
Update: it finally finished after 8.5 hours of processing. So going from 8.5 hours to 1.5 hours is a big, big win. Thanks so much.
For anyone interested, this is a commingling job. Checks and Remits. The Checks are portrait, the Remits are landscape and variable length.
One Data Map / Template pair for the Checks, a 2nd for the Remits. Commingle to produced a mix-plexed PDF. A new Data Map / Template to perform rotation per Thomas’ technique posted above. Then a last Data Map / Template to consume the rotated/fixed PDF and output PostScript with barcoding and media calls.
I am pleased that this approach was able to increase the speed so dramatically.
Of course, it depends very much on the performance of the computer (cpu speed, amount of cores) and a little bit on the license variant (output speed limit). But with this method you have the possibility to increase the power via different screws.
