I have a large array of metadata, and I have an issue within workflow where after updating the metadata using the “Lookup in Microsoft Excel” method I receive the below errors…
If I reduce the data quantity, there is no issue and the workflow completes without issue. After saving the metadata to a file it only generates a 34MB files, so I don’t think file size is the issue.
Anyone have any idea what is caulsing this?
[0024] [2024-07-26 13:39:31.765] Print content creation> Retrieving results
[0024] W3001 : Error while executing plugin: HTTP/1.1 500 An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the content creation process caused by ApplicationException: No record found with ID 873073 (SRV000022) (SRV000001)
[0024] Create Print Content: W1603 : Plugin failed - 13:39:31 (elapsed time: 00:00:03.544)
[0026] Starting plugin Create Job - 13:39:32
[0026] W3001 : Error while executing plugin: W4206 - Metadata does not contain valid Content Set Item Collection
[0026] Create Job: W1603 : Plugin failed - 13:39:32 (elapsed time: 00:00:00.045)
[0027] Starting plugin Create Output - 13:39:32
[0027] W3001 : Error while executing plugin: W4230 - Metadata does not contain a valid Job Item Collection
[0027] Create Output: W1603 : Plugin failed - 13:39:32 (elapsed time: 00:00:00.045)
