Load a dynamic PDF resource from a dynamic URL
I am trying to load a PDF as my background in designer (Print Section) from a URL, however I cant seem to get this to work, it only works with local resources, is this correct?? If so, whats the solution without downloading the files locally?
Unfortunately, at this point, there is no other option then downloading locally the PDF prior to using it.
Although, a workaround would be to have a branch in your Workflow process that goes through your data and temporarely download your PDF resources locally.
Then the rest of the process would run calling those now locally PDF.
Once done, simply delete the PDF.
Thanks hamelj, shame its not possible, thanks for the workaround, I was hoping I wouldn’t have to do this…
