List of DocumentIDs for all documents in repository
Is there any way for Workflow to get a list of DocumentID’s for all documents currently in the repository?
I’d like to be able to query a database for all existing doc IDs and see if the document is still needed in the repository. If not, I’d delete the document.
What documents do you mean? Capture OnTheGo forms? Or Connect documents used by Workflow?
For COTG documents, you only need to log in to your account on the server and view the list of current documents: Login
Hi Phil,
I’m referring to COTG documents. I know I can view the list of current documents if I login on the server, but I have a process in Workflow that needs access to a list document ID’s of every document currently in the repository.
Essentially I would like to use a Workflow process to automatically delete COTG documents from the repository as needed, but I need a way for workflow to know which documents are currently on the repository.
Everytime you upload a COTG Template to the COTG server, an ID is returned by the Plugin. Store those ID in the Workflow Data Repository and you will have a list of all COTG Form ID currently on the COTG server.
Then it is only a matter of maintaining the Data Repository.
Every time a COTG document has an expiration date, when a delete request is sent it errors, triggering an email in our workflow and sowing doubt as to whether the document expired or there was an error saving the id in the repository, or anything else happened. Has there any developments in this area since the last post in this thread? If no, what can I do to resolve the issues listed?
Building on the question above, how can I build a form in COTG that deletes documents of a specific kind (name, etc.) from the COTG repository?
