Hi - I have a bar chart and I am showing the value labels above the bar. There is one or two bars that are at the top of the value range and do not show the label because ( I am assuming ) not enough room. Is there a way to show all labels all the time? See picture below.
Try setting the “showAllValueLabels”: true for your “graphs” object(s) in the Source of the Chart Properties dialog (or add it to your JS code when scripting the chart). Info is taken from the amChart documentation, didn’t test it, so hope this helps.
