jquery-1.11.3 not supported?
I tried to implement a jquery based solution to resize the font. After including the jquery-1.11.3.js (via drag&drop to the JavaScripts folder in PlanetPress Connect and including it in my print template) and switching the view from design to preview and back there comes an error message:
TypeError: $(…)dy[PK] is not a function.
Detailed error message:
TypeError: $(…)dy[PK] is not a function in ‘Program Files/Objectif Lune/OL Connect/plugins/com.objectiflune.layoutengine.html.systemscripts_1.0.1.25203/scripts/systemscripts.js’ at line 1905
at com.objectiflune.layoutengine.html.js2java.JavascriptErrorHandler.onJavascriptError(Unknown Source)
at com.objectiflune.layoutengine.html.js2java.a.function(Unknown Source)
at com.objectiflune.layoutengine.html.embed.e.callJava(Unknown Source)
at org.mozilla.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Native Method)
at org.mozilla.xpcom.internal.XPCOMJavaProxy.invoke(Unknown Source)
at com.sun.proxy.$Proxy136.oL_evaluateJS(Unknown Source)
at com.objectiflune.layoutengine.html.embed.u.a(Unknown Source)
at com.objectiflune.layoutengine.html.embed.u.execute(Unknown Source)
at com.objectiflune.layoutengine.html.embed.Browser.execute(Unknown Source)
at com.objectiflune.layoutengine.html.MozillaBrowser.a(Unknown Source)
at com.objectiflune.layoutengine.html.MozillaBrowser.execute(Unknown Source)
at com.objectiflune.layoutengine.html.pagination.i.run(Unknown Source)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at com.objectiflune.layoutengine.html.pagination.PaginationProvider.revert(Unknown Source)
at com.objectiflune.contentcreation.html.mergeengine.impl.HtmlMergeEngine.revert(Unknown Source)
at com.objectiflune.application.designer.editors.TemplateEditor.C(Unknown Source)
at com.objectiflune.application.designer.editors.TemplateEditor.access$7(Unknown Source)
at com.objectiflune.application.designer.editors.ar.run(Unknown Source)
at com.objectiflune.application.designer.shared.internal.a.run(Unknown Source)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at com.objectiflune.application.designer.editors.d.run(Unknown Source)
at com.objectiflune.application.designer.editors.HtmlEditor.withoutRedraw(Unknown Source)
at com.objectiflune.application.designer.editors.av.runInUIThread(Unknown Source)
at com.objectiflune.application.designer.editors.HtmlEditor.runJob(Unknown Source)
at com.objectiflune.application.designer.editors.TemplateEditor.onPageChanged(Unknown Source)
at com.objectiflune.application.designer.editors.HtmlEditor.pageChange(Unknown Source)
at org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(MultiPageEditorPart.java:290)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2746)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1433)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.objectiflune.application.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
What can I do to use jQuery in PlanetPress Connect?
PlanetPress Connect Designer version: 1.1.0.25554
Best regards,
Thomas
This approach is not supported. A jQuery instance is already running for the underlying pagination algorithms. So there is no need to add that. One has to be careful with adding custom JS code for Print contexts. It could interfere with the pagination algorithms and the other way around, so make sure you test your output. FYI. I got a working sample based on jquery-textfill, if you are interested I could share that with you, let me know (GitHub - jquery-textfill/jquery-textfill: Resizes font-size of text to fit into container).
Thank you for your answer. It would be great of you to share your solution with me.
Yes, me too, please :slight_smile:
Is there any place at “OL Learn” where that kind of shared ressources can be downloded from?
Attached a sample template & datamapper created in Connect 1.2. Hope this is of some help. Note that the textfit option is on our product backlog and will be implemented as a native feature in a future version.
Thank you for the sample files.
