Javascript, the DOM, and creating elements
I’ve written some javascript code to handle formatting nested lists. There may be a simpler solution, but this is what I have currently. My question is – In designer, is there a way to access the document element of a print context? When I attempt to use document.getElementById for instance, it states that the document is not defined. This makes sense, but I’m wondering if there is a workaround for me to manipulate the given HTML with my script, while at the same time accessing the record set data? I need a simple way to create elements and whatnot dynamically.
let string = “1. this is the first thing 2. this is the second thing a. this is the thing nested in thing 2”
var stringArray = string.split(/([1-9].|[a-z].|[a-z][a-z].)/)
stringArray.shift();
let length = stringArray.length;
let newArray = ;
for(i = 0; i<length; i+=2) {
newArray.push(stringArray[i] + stringArray[i+1]);
var list = document.getElementById(“list”);
newArray.forEach(c => {
let split = c.split(‘’);
if(split[0].match(/[1-9]/)) {
var elem = document.createElement("li");
var t = document.createTextNode(c);
elem.appendChild(t);
list.appendChild(elem);
} else if(split[0].match(/[a-hj-z]/)) {
var nextList = document.createElement(“ul”);
var elem2 = document.createElement(‘li’);
elem2.appendChild(t);
nextList.appendChild(elem2);
list.appendChild(nextList);
} else if (split[0].match(/i/)) {
var nextList2 = document.createElement(“ul”);
nextList2.appendChild(nextList);
list.appendChild(nextList2);
Desired output, which my javascript achieves but not with Designer:
Most of this is handled by special methods in Connect. For example, to get an element by ID, you’d use Query
http://help.objectiflune.com/en/planetpress-connect-user-guide/2018.1/#designer/API/query.htm
Inserting elements into the DOM would be done via the results object:
http://help.objectiflune.com/en/planetpress-connect-user-guide/2018.1/#designer/API/results_Object.htm%3FTocPath%3DTemplate%2520Design|Script%2520API|Designer%2520API|results|_____0
This was my solution to solve my problem:
let string = record.fields.technicalSummary;
var stringArray = string.split(/([1-9].|[a-z].|[a-z][a-z].)/);
stringArray.forEach(function(c) {logger.info(c);});
let newArray = ;
for(i = 0; i" + c + “”);
logger.warn(c);
builtElement += query(“#technicalList”).add(“” + c + “”);
results.html(builtElement);
