Javascript Location for CSV databases
Hi All
Quick question.
For a particular database I need to assign a separate field with a number based off data from a existing field.
For a another database i used the following and it seemed to work
data.extract(‘./CUSTOMER[1]/Country[1]’);
var myData = data.extract(‘./CUSTOMER[1]/Country[1]’,0);
if (myData==‘CA’)
‘1’;
else {
if (myData == ‘US’)
‘2’;
else
I got the data location from the datamapper where it had a field XPath:
Now for a CSV file it doesnt seem to have a XPath:
Mode: Location
Column: (field name)
As a example, lets say the column I need to use is called State
Mode: Location
Column: State
top offset: 0
I created a new column called insert to use this
How would i change the previous script to reference this column?
Would the mode still Location then type in Post function:
Or would it be same as previous javascript.
EDIT
It seems Just typing the column name seem to have worked, but realised the issue was more for the actual script.
I presumed if there is more then 2 variables, for example VIC gets 1, NSW gets 2, QLD gets 3 then the if and else doesnt seem to work?
Not well versed in javascript
Many Thanks
Best Regards
Jason
For a CSV file you can’t use xPath, but it has a columnName and a rowOffset.
From online help:
data.extract(columnName, rowOffset)
Extracts the text value from the specified column and row.
columnName: String that represents the column name.
rowOffset: Number that represents the row index (zero-based), relative to the first row in the record. To extract the first row, specify 0 as the rowOffset.
Small clarification on MartinS’ answer: the rowOffset parameter for the data.extract() method is relative to the current position (and not to the first row of the record). So for instance, if you have a Goto step that jumps to the 10th line, issuing a data.extract(“MyField”,0) command immediately after it would extract the value on the tenth row, not on the first one.
Hi Phil,
Sorry for necroing this. Can I use a negative value for the rowOffset? If say -1, which row does it refer to?
Thank you
It refer to the row before or, when there is none, the below error will occur.
[...] The step is out of bound 0 (DME000220)
