Has anyone else been having issues with workflow losing connection to the engines when running jobs? Getting varying error messages on varying jobs
Error while executing plugin: HTTP/1.1 500 An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the content creation process caused by ApplicationException: Render process crashed. Status: TS_PROCESS_CRASHED, error code: -36861, error message: Crashpad_NotConnectedToHandler
W3001 : Error while executing plugin: HTTP/1.1 500 An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the content creation process caused by ApplicationException: Connection to the Merge Engine (PID 20512) has been lost
I agree that opening a ticket would be best, but to help you prepare for that: It sounds to me like the merge engine ran out of memory. In that case there may be other indicators in the merge engine logs.
Yeah I’ve created a ticket and they said "I’ve cross referenced the errors between engines and server and i’ve not seen anything specific being indicated by the errors other than some issues communicating between engine.
There are a couple regarding data matrixes can’t be generated so that could indicate that there are some issues with the data for the data matrixes"
Told me to try restarting the services which I have but still hasn’t fixed it. Just trying to see if anyone has had the issue as I’ve not had a response from support
Then it is most likely due to the kind of jobs you are using VS the data in it. If you can reproduce it at will, I suggest you provide that to support so they can in return try and reproduce and then escalate to R&D.
check if hardware acceleration is enabled for your GPU on the system and if it is, disable it
disable any antivirus
Since you mention you have a test system, running these tests on that system will do no harm.
I’m basing the suggestions on info gathered from the web, so it may not apply to your particular situation, but I figured it wouldn’t hurt to mention it.
Can you please check the OL Connect resources in the Designer and, if possible, load the input as data sample? Especially, check if there is an issue with a data matrix element. Because I see that the merge engine logs contains loads of An error occurred generating the Data Matrix errors that are followed by Error writing PDF data (CC1000101) … Render process crashed … Out of Memory errors. It sounds reasonable to me that this is resulting in this issue.
We have encountered an “Connection to the Merge Engine (PID *****) has been lost” error a few days ago. After reducing the amount of Merge Engines from 10 to 6 all jobs could be processed without any problems.
This error appears all the time it seems after spending time with Ryan at supporting looking at the logs on a different issue, so I don’t think it’s this
