Installer not Running
I run the offline installer select English but then nothing happens, for about 15 mins there is a process running called Objectif Lune Connect Pre Install but that ends with nothing happening.
My server is 2012 R2 64 bit and has no internet connection but I have installed the Go-Daddy certificates
Firewall is off, any ideas?
Dear user,
can you please have a look at the installation logs? You can find them under C:\Users\Connect\logs\Installer.
For use that name, under which account you run the installation.
The Connect installation procedure will usually write two log files, one named “Installer_.log” and another named “OL_Install_.log”.
indicates the date, when that log file has been written, indicates a unique time stamp.
Please put all the respective log files here for analysis.
This is the entry
2017-02-23 15:10:45.613 [L] Error in Java launcher. Error: 101
Method: verifyEmbeddedSignature
Message: WinVerifyTrust failed with error 0x80096005 C:\ProgramData\Objectif Lune\ConnectSetup\plugins\com.objectiflune.equinox.launcher.win32.win32.x86_64_1.6.1.35991\eclipse_vc10.dll
I am guessing there is something not working regarding the certificate
this is a known issue and is related to one or several certificates missing on your computer. We have a PDF available, which describes, how to check all this and fix it. If you tell me your mail address, I’ll send it to you.
please send to solarcarrot@icloud.com
did you receive the PDF? Did it help to solve your problem?
I believe I am having this same problem, but the log files aren’t being created. The other symptoms are the same. How can I get this PDF you mention?
Thanks,
Glenn
Never mind. It was the anti virus. All good now.
