Is there a way to insert a blank page after the first page in a PDF within Designer?
How about making the section duplex?
- Choose: Section > Sheet Configuration
- Select Duplex
When you don’t want content on the back side (for example when showing T&Cs from a Master page) you could set the “Allow content on” to “Front only”
I am using the PDF as the data source and it contains 3 pages per record. I need to insert a blank page after the first page.
I was able to get the job completed using the old designer but would like to be able to do it in the new designer next year.
This can be achieved by setting the document to duplex and change the Sheet Configuration for the First Sheet, Middle/Last Sheet
- Select Duplex
- Untick the Same for all positions
- Set Allow content on for the First Sheet to Front only
- Set Allow content for the Middle and Last Sheet to All sides
Think that should solve it. Let me know how it goes.
That worked. Thank you.
