Came back from vacation and tried to do the updates to 2024.1 using the update manager and the install crashed after uninstalling my current versions and I had to start from scratch. Installed the 2023.2 version but now connect messenger won’t install so I can’t do anything!!!
Given the severity of the issue, I’d recommend raising a support ticket via the Customer Portal, or by sending an email to ol_support@uplandsoftware.com
On some occassions the Messenger not being able to be installed is due to disk space. Connect needs at least 20GB free in order to successfully install, and if there is not enough free space then Messenger seems to fail.
There are log files under C:\ProgramData\Objectif Lune\Installation Logs and C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\Installation Logs which might shed some light on the cause.
This isn’t isolated. On my last 3-4 updates, Messenger always fails to install. I have to first install, then do a “repair installation” to get a successful installation.
I had the same problem. The problem is coming from the Workflow installer.
I solved it to uninstall all OL software manually in the following order:
Uninstall Messenger
Uninstall LincPDF
Uninstall Update Manager
Uninstall Workflow
Uninstall PlanetPress
If you don’t use this order, it is possible you are unable to uninstall some parts, and you need to use the software cleanup tool that Upland can provide or install the old version and start over again.
Then first install and this is important OL Connect Server. This one successfully install Messenger. After that you install Workflow, because messenger is already installed the workflow installer ignores the messenger installer.
Upgraded 3 systems this month this way and no problems.
ps. i NEVER use the update Manager. This give me more problems then doing it manually.
