How can I achieve what the title reads. I have made a data mapping config using the PDF as data and created a template with duplex setting. In Workflow I created a folder capture, using the All in One to a LPR print queue.
If you have Workflow and the only thing you want is print an existing PDF in duplex, it could be done much more efficiently by using the Print using a Windows Driver output task and set the printer queue properties to duplex.
Thanks for the suggestion however I already tried that and the printer still does not duplex print. The printer is a Konica Minolta C652 with a Fiery controller E10-501E.
I would prefer a LPR solution however. Any other takers?
