I keep getting: ApplicationException: The impositioned pages will not fit on the selected media size
I seem to be running into a bit of a problem in my planet press workflow, I keep getting the same error while running my All in one plugin.
The Template is made up out of sections with A4 size and in the output they are impositioned 2up on SRA3. The first page of the template has a bleed 210 mm to the right.
I keep getting this error in my workflow.
10:19:56.994 W3001 : Error while executing plugin: HTTP/1.1 500 Internal Server Error LoggedApplicationException: There was an error running the output creation process caused by There was an error initiating to the output creation process caused by ApplicationException: The impositioned pages will not fit on the selected media size.
10:19:56.994 All in One: W1603 : Plugin failed - 10:19:56 (elapsed time: 00:00:04:746)
I have an identical plugin in my workflow(It’s almost in the same place, they are separated by a condition based on their name.) That seems to work just fine.
Ok, I replaced the Media with a new one and now it’s working. :grinning:
