I have a Connect designer form that is on letter / landscape paper. I render it as PCL then send to a remote queue using LPR. The remote queue (equitrac) sees the job a Executive paper size. I suspect that this is a default or error at the EQ end. I have even edited the PJL to insert the @PJL SET PAPER=LETTER to no effect. Yet, the EQ people are pretty sure that EQ just reads the incoming job for papersize… so am I inadvertently cueing the wrong papersize somewhere?
We would need to look at the PCL as the Job/File will include the papersize… if it is not a standard ( Old issue if you include Bleed it increased the pagesize) it becomes custom and that may cause the printer to use the default
