Is there a way to auto create hyperlinks, when a text message is passed from a Parameter into the Datamapper/Template.
In my example I place this text from a parameter into a Datamapper/template:
Text from workflow (SQL DB):
“Hvis du har spørgsmål eller brug for information om dine rettigheder kan du ringe til Region Nordjyllands Patientkontor alle hverdage mellem kl. 9-12 på tlf. 97 64 80 10. Få vejledning hos Patientkontoret”
Is there a way to recognize an https address as a hyperlink, and auto create the hyperlink - when placing text.
So by doing this in a script in a Template, you manually extract the URL part into a <a href=“[url]”>[url name]</a> and merge all this into a text on your Template.
